Motech said
"If you do not get any Thermacter Air Injection codes, you can put this to bed as no problem."
Do you recall that the valve diaphragm does not hold vacuum? I do trust your opinion based on your years of experience and appreciate your sharing your knowledge so freely but I figured to replace it just based on the fact that the diaphragm leaks. That was assuming that I could get the part.
I have already tested both TAD and TAB solenoids by removing them, switching them with 12vdc and confirming that they actually do open and close using a vacuum gauge. Then I installed them and checked the vacuum hoses to their respective valves and both deliver vacuum to the valves without leaks. I have also run the self test and the truck has no codes.
Wouldn't you replace it for one that doesn't leak if it was your car?
