More then likely you have rust on the driver side floor are. Like when it comes a heavy rain. The floor gets(or got wet) Its because the vent in behind the emergency brakes lest water in. The reason is . The big bulge behind the fender catches all the water and it over fills. The reason it over fills is from all the years of leaves and dirt stops up the little drain hole between the bulgs and body. What I done to correct it is cut two good size hole in the bottom of each bulges. Now I can take a 5 gallon bucket of water and pour it in and nothe=ing gets in the floor. You can see the picures in my section.What they look like. Good luck.You might want to think about drilling a drain hole below the spring shackle. Not draing. It catches and holds grave,mud and will cause it to rust out.
