Speedo gear on 1356 rebuild
autobahnaudi
Rebuilding a spare 1356 with electronic shift that I picked up. Pulled off the cover and I'm not seeing that it has a place to install or ever had the yellow speed gear like in this rebuild link here. http://www.fullsizebronco.com/forum/showthread.php?t=135334
Do all 1356's have this? Searched for about an hour now can't find a direct answer.
Just need to know if I need to buy and install one or not. My 1356 shaft doesn't have the ball bearing piece where the speedo gear would be either. A bit confused....
yo autobahnaudi,
93 Ford Bronco, Correct?
If so;
That article by allfordman describes pre-92 years where VSS is mounted on transfer case tail housing
Your 93 has the VSS mounted on the rear differential as shown in this pic by Mark Z
Your VSS Path is from Rear Anti-Lock Brake System (RABS) Sensor (also called Vehicle Speed Sensor (VSS) & Differential Speed Sensor (DSS); through Connectors & 4WABS Control Module, etc to PSOM, PCM & E4OD & to Cruise (Speed Control), etc.
So you need not do anything relative to that yellow speed gear or ball bearing piece where the speedo gear would be either.
A
autobahnaudi
Yep it's a 93. That explains everything , had me stumped I got a lot to learn over the next few months my rig is getting a pretty serious overhaul.
Thanks!
yo RON,
I did not see yopur reply because it wasn't visible when I began my response, thanks to the NEW SUPER INCREDIBLY SLOW INTERNET SPEEDS that COMCAST provides with their UPGRADED BLAST that now COSTS $100.00 per Month!
By the time I was able to get the Replay sent, you had replied, but I did not see it.
It took me a few years to get all the VSS, PSOM vs Speedo and a zillion other thAngs straight; am still learning, but I forget what I knew last year! lol
Coastersfwb
