LIFT KITS!
Dan T
Hermiston, OR
What is a good brand to go with on my 91 bronco i want to go 4 inch lift. and if i do can i fit 35's without a problem?
Rons beast
Welcome Dan.
35s will fit with a min. 4" lift. What kit to buy is a matter of personal perference, and your mechanical abilities, and your budget. Call the suppliers or better, the manufacturers if you can, and give them your plans and ask all the questions. before you buy.
There were some others on here that had problems with some kits, then found the support to be about nil.
I don't remember the name of the companies, but I will try to look up the threads and get that info to you.
Good Luck and welcome again.
