Yo Mike,
TY!
Troubleshooting; "...If you have a problem when turning on one circuit it causes another to come on partially (dim lights, etc.), check the ground for the part or system that was turned on first. i.e., if you press the brake pedal & the parking lights turn on partially or fully, check the brake lights' ground; This is caused by current going thru da brake light bulb filaments & finding a ground in the parking lt. system instead of its own ground..." by me
Headlight, see this wiring diagram...
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=46703
Left headlight uses different ground, g100, than right hl. So, take a look at it. There is a splice though between hl and g100. Will give you a location if you need it.
Check other grounds as well. On all battery and other cables/wires, look for corrosion on the cable or wire close to the connector, lug, etc. Sometime corrosion forms under the connector, lug, etc. As well as around each wire strand.
Locations & Components in a 96, about 99% same as your 95; G101 front of engine compartment, front of fender apron (D1) - RH = Passenger side mine has 2 small black wires between starter relay & headlight; this is #5 in the diagram; G100 & G104 (tied together in diagram); G100 @ LH front of engine compartment on upper radiator support; G104 @ Rear of LH fender apron near hood hinge and 4WABS Test Connector (RED); G100 Serves Component, LH Oxygen Sensor, Fuel Pump Module, Inertia Fuel Shutoff, Misfire Sensor, Misfire Sensor Shield, Output Shaft Speed (OSS) Sensor, Powertrain Control Module (PCM) 5.0L; G101 Serves, RH Oxygen Sensor; G104 Serves Component: 4WABS Control Module, 4WABS Data Link Connector, 4WABS Relay #1, Instrument Cluster, Powertrain Control Module (PCM) 5.8L, Powertrain Control Module (PCM) 5.8L, Programmable Speedometer/Odometer Module (PSOM), Trailer Relay Box; G103 (battery to engine) Lower RH front of engine serves Component, 4WABS Pump Motor, Battery, Data Link Connector (DLC), Mass Air Flow (MAF) Sensor, Powertrain Control Module (PCM) 5.0L, Powertrain Control Module (PCM) 5.8L, Right Front Park/Turn Lamp, Right Front Side Marker Lamp Right Headlamp; G201 Behind bottom of LH cowl panel (driver's side kick panel) Component, Compass/Outside Temperature Module, Day/Night Mirror, Inside Cargo Lamp, Left Power Lumbar Compressor Motor, Outside Cargo/High Mount Stop Lamps, Right Power Lumbar Compressor Motor, Seat Belt Switch, Door Lock Actuator (PDL & Probably Power Window Motor); G200 Behind bottom of RH cowl panel serves Component, Air Bag Diagnostic Monitor, Electronic Shift Control Module, Instrument Cluster, Programmable Speedometer/Odometer Module (PSOM), Remote/Keyless Entry Module, Speed Control Servo/Amplifier Assembly; G103 (battery to engine) Lower RH front of engine serves Component, 4WABS Pump Motor, Battery, Data Link Connector (DLC), Mass Air Flow (MAF) Sensor, Powertrain Control Module (PCM) 5.0L, Powertrain Control Module (PCM) 5.8L, Right Front Park/Turn Lamp, Right Front Side Marker Lamp, Right Headlamp; G400 Rear Window Defroster @ LH rear corner of cargo area, near rear lamp assembly; Engine Block pic in a 94 5.8; "...The black battery wire goes from the front bolt of the engine mount (on the block) to this tab & up to the battery post, where a smaller black wire goes to the core support, providing a continuous ground path between the engine, frame, battery, & body; Frame & Battery pic in a 93; "...With the wheelwell gone, it's easy to inspect the frame ground, just inboard of the spring tower on top of the frame rail. The battery ground cable is stripped ~3/4" and a tab is soldered on so it can be bolted to the frame; Intake Manifold to Block Strap Location in a 96 5.0 is between 2nd & 3rd plugs on passenger side; SEE DIAGRAMS
by me at...
http://broncozone.com/topic/20952-loose-ground/page__pid__109954__st__0&
Here are ground diagrams in your 95 5.8
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=9877
And wiring diagrams, same as in Ford manuals,
