Milo,you might try changing the place where you get gas...Fords are bad about spark knock when running poor grade of gas...myself i try too run only shell or bp...any gas other than these little kwiky marts...i stop once and by mistake grabbed unleaded(87 octane) and i have never had my bronco cough and fart and rattle or spark knock like that...i stop that saturday and filled her up at shell with unleaded(87octane)and ran like a totally different truck...you might start there and see if it makes any difference.....good luck.... B)
I'm with you dog!
I tried Wawa (local con. store chain) for 3 months and the 96 developed a ping.
So,
TOP TIER Gasoline Retailers; Gasoline retailers must meet the high TOP TIER standards with all grades of gasoline to be approved by the automakers as providing TOP TIER Detergent Gasoline. Source: by toptiergas.com
an excerpt; since the site is temp. down"..."..TOP TIER Detergent Gasoline is the premier standard for gasoline performance. Six of the world's top automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi recognize that the current EPA minimum detergent requirements do not go far enough to ensure optimal engine performance.
Since the minimum additive performance standards were first established by EPA in 1995, most gasoline marketers have actually reduced the concentration level of detergent additive in their gasoline by up to 50%. As a result, the ability of a vehicle to maintain stringent Tier 2 emission standards have been hampered, leading to engine deposits which can have a big impact on in-use emissions and driver satisfaction.
These automakers have raised the bar. TOP TIER Detergent Gasoline help drivers avoid lower quality gasoline which can leave deposits on critical engine parts, which reduces engine performance. That
