tjg8675
- Joined
- Sep 3, 2007
- Messages
- 102
- Reaction score
- 10
Hi All,
I have a 1995 Bronco that I've done a "Saginaw" power steering pump conversion and I'm having an issue where the pump seems to lose power and makes sort of a grinding sound at idle when I'm turning the steering wheel. This happens when I'm trying to do low speed maneuvering such as parallel parking or turning up onto a curb when the pump has to do extra work.
It doesn't do it when driving above idle or when turning on wet or slick/polished pavement surfaces, only when steering when the engine is at idle on normal, dry & stickier than normal pavement surfaces or when turning the tires against something like a curb or rock. I had both a rebuilt Saginaw power steering pump (from older E150 van w/ stock pulley) & a rebuilt Steering gear installed when the Saginaw conversion was completed.
My initial thoughts are that the pulley may not be spinning fast enough at idle and am wondering if a larger pulley might solve the problem.
Thanks in advance for any help trouble shooting this annoying issue
