Unthrottled
I'm having trouble diagnosing an intermittent fast idle problem on my stock 1994 Bronco XLT, 5.8L. I'd sure appreciate any ideas you might share.
The problem occurs sporadically both in Park and in gear while I'm driving. It's worse when I first start the car up. After a hour or two of driving, it usually disappears. The more the car sits, the more frequent the problem. The more I drive the car, the less often I get a fast idle.
I can sometimes get it to go away if I put the vehicle in neutral and rev the engine. But this doesn't always work.
I can also sometimes get it to go away if I turn off the car and restart it. But this also doesn't always work either.
I replaced the Throttle Position Sensor, but this did not fix the issue. Also replaced the Idle Control Valve, but no improvement.
My mechanic friend wants me to keep throwing parts at it. I want to diagnose the problem first.
Oh, two last things. The problem first started after the car had sat unused for a few months while I was moving my family across the country.
Also, I occasionally get a rough idle at start-up.
I don't know if that might help someone with more mechanical knowledge than me narrow down a diagnosis.
I'd be very grateful for any ideas or suggestions. What could be causing my fast idle?
Thanks!
Thanks!
