jimko
I am helping my daughter with her newly acquired (for free!) '78 Bronco. Odometer shows 3k miles (103k likely and hopefully). Don't know if its a 351 or a 400. It has sat for 8 years due to not passing smog. At this point we are just going to try and get it to turn over but before doing that I was advised to squirt ATF in the cylinders before rotating the crank to help loosen the rings. The oil looks clean and full on the dipstick, the coolant is full and not dirty, and the trans fluid is a nice reddish color. I am not sure whether it would be better to go to a 4 barrel carb and intake if that will jeopardize passing smog, the old 2 barrel was rusty corroded junk so thinking of 2 barrel replacement for starters and upgrade later. Also there was a rats nest on top of the motor so the ignition wires are chewed up. Starting with new plug wires, the plugs all looked ok with some black carbon so I just cleaned, re-gapped, and re-installed them.
So that's where things are at the moment, I would appreciate any advice before we try and get things rotating.
Thanks in advance!
Thanks in advance!
