Won't Go Into 4wd
sbveenker
Ok i have a 1994 eb Bronco. Its pretty much stock, for a little bit, and I go 4wheeling a couple times a week. Today there was a bunch of snow so i pushed the button to go into 4wd and i could hear the normal clicking sound by the passenger side door but it never engaged. Any suggestions
swampthing
New Jersey
hit the motor with a hammer...good possibility the motor went bad.if so you just gotta change the motor out
Yardape
Alberta
Check all connections to the motor on the transfer case. Then tap the motor with a hammer. And try again, using the procedure stated on your visor.
Wdtdls
