Won't Go Into 4wd
sbveenker
Ok i have a 1994 eb Bronco. Its pretty much stock, for a little bit, and I go 4wheeling a couple times a week. Today there was a bunch of snow so i pushed the button to go into 4wd and i could hear the normal clicking sound by the passenger side door but it never engaged. Any suggestions
swampthing
hit the motor with a hammer...good possibility the motor went bad.if so you just gotta change the motor out
Check all connections to the motor on the transfer case. Then tap the motor with a hammer. And try again, using the procedure stated on your visor.
