transfer case
Bcrump5252
stupid question on transfer cases, my bronco is currentley runnign an np 435, what are my other options its a 4 speed and I want to keep the 4 speed or go to a 5 speed.
she's my weekend toy, I take her to uwarre national forrest and to telico I do alot of 4 wheeling not much mud mostly rock crawling.
thanks for any imput
S_bolt19
Colorado
You have the Dana 20 xfer case and in combination with the NP, there is not another transmission that will give you the low range that you currently have. Here is a link to a trans/xfer/gear calculator that you can test out different combos of them on. You will find that no matter what, if you use the same axle & xfer case, there is not another trans that will be lower than the NP435.
https://home.comcast.net/~jcmiley/bronco%20gears.html
figjeti
