starter /ignition problems
rpys44
OK, I HAVE REPLACED STARTER , SIDE WALL STARTER RELAY OR (SOLENOID )
IGNITION SWITCH , UPPER KEY CYLINDER SWITCH , AND ALTERNATOR .
I HAVE RETURNED 3 SIDE WALL RELAYS ALREADY .
I WENT TO START BRONCO , AND STARTER REMAINED RUNNING , WENT TO DISCONNECT (S) WIRE
BUT KEPT RUNNING , DISCONNECTED BATTERY CABLE STOPPED . TRY TO CONNECT BATTERY AGAIN BUT WANTED TO START WHEN IGNITION IS IN OFF POSITION , WHY?
IN CASE my PM reply to you did not go thru
For now; I have a doc appointment this afternoon;
There is a possibility of a bad ignition switch, but it needs to be tested first.
see Logic Table in:
Lock Cylinder Adjustment & Switch Pin-Out Diagram & Continuity Testing (Logic Tables) in an 83; "...The following proceedure is from the 1983 Ford Service manual, with a few minor wording changes, but should work for any year. Also included are a couple of illustrations from the same proceedure to help you visualize it..."
Source: by Seabronc (Rosie, Fred W) at http://broncozone.co...?showtopic=7243
Ignition Actuator rod is sticking. Might be broken,
It runs from the top of the steering column down to the IGN switch, put your hand on that rod and see if it moves when you turn the key.
Parts Break-Out Diagram in 80-91 Tilt
Source: by Steve
http://www.supermoto...try/media/72346
Replacing the actuators is a PITA, even though the parts are cheap & easy-to-find at parts stores for ~$20ea. Call your local used car lots & independent repair shops for the number of a local steering column specialist. If he'll rebuild the column for less than $120, pay him.   read more
Be Well!
tsebalj
