Gear Shift ****
Straight6
Does anyone know where I can get a shaft **** for a SROD transmission. I need one because I will not be the only person driving this Bronco.
Shouldn't be hard to find a shift **** at a auto recycler or just get a custom one. As long as the driver knows where the gears are, you don't need the diagram. Can't see it any way when your hand is on the shift.
This is a perfect opportunity to build one out of a piston.
I've use weed wacker pistons and a few others from small engines.
I'll have to get some photos because its a ******* look and has a good feel after you grind the top edges round.
That piston idea sounds interesting I look forward to the pics. Thanks to all for the help.
squatch23
Back
