full size Bronco, F-150 Doors
budster 95
Pocano Mountains, northeast PA
Wondering if 94 F-150 doors with manual window cranks, and manual door locks, have the mounts for my power window, and power door lock set up in my 93 full size Bronco. My uncles F-150 was rear ended, now he is donating some parts to my Bronco project. Anyone ever done this swap? Thanks-Bud
yo BUDSTER,
I am 99.99999% sure that you can swap the doors & convert;
Manual to Electric Swap Info in an 89 (pics are gone)
Source: by 89_outlaw (James);
finally got around to putting in my PDL and PWs today.. here is a lil how to, time spent, problems, what was needed:
Time Spent: 2 hrs
Problems: None, you'll need the plug and play wiring harness for these if not so equiped, mine already had it making the job less time comsuming.
Tools needed: Drill, 3/8 drill bit,small 1/4 dr rachet with 6" extension, assorted small sockets.. depending on whats in your truck. a lil pbs blaster or equivelent to make things go a lil smoother and all the parts needed for the swap
How to: Change from Manual to elec, power windows and door locks
1st off, took off the rotted door and installed the newer manual operated door to the body. less heavy without all the extra stuff. layed the elc windowed door beside the manual
2nd work all the wiring off the elec door
3rd, the lock actuator is pop riveted in if from factory so you'll have to drill this out
4th I went ahead and took the door latch out to save or get rid of and it made more room to move around
5th with a hammer knock in the end of the pop rivets, ya don't have to hit it hard they pop right in then drill out the PR heads
6th take out the 2 screws that hold the vent window on this part of the door and the bolt that was over top the rivets ya just took out.. as you pull out the vent window pull it back towards the back of the door and pull up when it stops turn 90 degrees to get past the attaching tab. the rubber around the window also comes out with this
7th.. once you've got the 4 rivets out becareful becuase the window is going to slide down.. making it easier to get out.. on the window slider simply pull back on the window gear assemble until it slides out of the rail
8th remove big glass.. this should leave your elec door almost stripped.. manuvere the gear assembly and remove from door
thats it.. the door is gutted..
Now do the same to the manual door.. install is reverse what ya just read, clean up and lubricant all parts while out of door makes for a cleaner job
you can use 3/8 bolts and nuts but I was fortunate enough to have a cousin in the glass business who had a Heavy duty rivetor so I reriveted everything that was riveted onto the new door, replace the exterior locks and ya should be in business
keep all the extra parts such as door handles, vent window and so forth, cause ya never know when you'll need em.. or ya can simply sell em or give em away..
Hope this helps someone in need.. thx for looking/reading
James..."
Motor Models - the split between models of the 92 (for power window motor purposes) occurs in May. If it was made BEFORE May, the window motor is the same as a 91. Otherwise, the motor is the same as the 92-96.
So, you're ok on that too.
here is a door install by Steve
He swapped a 95 door into his 83; plus, "The body tub is an '82, the tailgate is a '96, the doors are '80 & '94 with '94 power mirrors, the front clip is '84, and the camper shell is a '96 with a '94 Explorer roof rack & '82 sliding windows."
For door alignment, see this:
For more about Doors, see this album:
Parts Diagram
Power Window, Power Door Lock, Power Mirror & Speaker Harness & Connector Location & Removal from Door in 92-96; "...The passenger door harness disconnects inside that kick panel. But the driver door harness is continuous from the door lock motor all the way over to those passenger connectors. Either pull the dash, or disconnect everything inside the driver door, and then feed the harness out of it as you remove the door. I'd just unbolt the hinges & hang them both from a beam across the roof of the truck, leaving the wiring connected..."
Source: by Steve83
Also;
Doors Removal
Disconnect the battery ground cable (14301).
Remove any door trim necessary to access the electrical connector inside the front door (20124). Refer to Section 01-05.
Disconnect the electrical connector inside the front door and pull the wire harness out of the front door.
NOTE: When marking hinge locations, use a felt marker or equivalent. Do not scratch the paint.
Mark the door hinge locations to aid installation alignment.
Support the front door.
Remove the lower door hinge-to-front door bolts.
Remove the upper door hinge-to-front door bolts.
Remove the front door from the vehicle.
Installation
Support the front door in position at the door hinges.
Align the door hinge-to-front door match marks made at removal and install the upper door hinge-to-front door bolts.
Align the door hinge-to-front door match marks and install the lower door hinge-to-front door bolts.
Align the front door. Refer to Adjustments in this section.
Tighten the door hinge-to-front door bolts to 26-35 Nm (19-26 lb-ft).
Feed the wire harness into the front door and connect the electrical connector.
Install any door trim removed to access the electrical connector.
Connect the battery ground cable.
Front Door, Bronco and F-150, F-250, F-350 and F-Super Duty Chassis Cab
Item Part Number Description
1 22810 Door Hinge, Upper
2 20124 Front Door
3 N803417-S36 Bolt, Door Hinge-to-Front Door
4 22800 Door Hinge, Lower
5 02500 Front Body Pillar
6 N803417-S36 Bolt, Door Hinge-to-Front Body Pillar
A � Tighten to 26-35 Nm
(19-26 Lb-Ft)
1 21402 Front Door Vent Window
2 21448 Weatherstrip, Front Door Vent Window
3 21596 Front Door Glass Top Run
4 21410 Front Door Window Glass
5 21458 Front Door Glass Channel and Retainer
6 351909-S ****** Front Door Vent Window Frame-to-Front Door Vent Window Division Bar
7 21452 Front Door Belt Line Outside Weatherstrip
8 21456 Front Door Belt Line Inside Weatherstrip
9 22A00 Front Door Glass Run Latch Side Retainer
10 23240 Window Regulator Arm Roller
11 23200 Front Door Window Regulator
12 23342 Window Regulator Handle
13 23370 Window Regulator Handle Plate
14 23227 Window Regulator Handle Seal
15 22926 Pivot Spring, Front Door Vent Window
16 22963 Pivot Washer, Front Door Vent Window
17 22916 Front Door Vent Window Handle
18 21608 Frame, Front Door Vent Window
19 21408 Weatherstrip Retainer, Front Door Vent Window
20 22296 Division Bar, Front Door Vent Window
21 23208 Front Door Power Window Regulator Minus Motor
22 385189-S Rivet
23 23394 Window Regulator Electric Drive
24 234A24 Window Regulator Drive Gear Kit
LUBRICATION
Weatherstrip
Use Silicone Lubricant C0AZ-19553-AA (jelly) and D7AZ-19553-AA (spray) or equivalent meeting Ford specification ESR-M13P4-A on the door and window weatherstrips whenever necessary. Silicone lubricant helps avoid weatherstrip squeaks and retards excess weatherstrip wear from chafing between the door glass upper frame and the weatherstrip. It also helps to retain door window alignment by reducing friction between the glass frame and the rubber weatherstrip.
Hinge, Door and Tailgate
Use Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs.
budster 95
yo BUDSTER,
Time Spent: 2 hrs
James..."
Parts Diagram
Source: by Steve83
Also;
Doors Removal
Installation
2 20124 Front Door
(19-26 Lb-Ft)
22 385189-S Rivet
LUBRICATION
Weatherstrip
Miesk 5, as always you come through with exactly what i need. Thanks so much, your time is appreciated!
budster 95
I did the door swap a while back, from an F-150 doner. Didnt get around to posting till now. I only had to drill one hole, that wasnt in the (manual window/door locks) door, for the power door lock solinoid. Worked out great, thanks for the advise. I found a good tailgate this morning, gonna go p/u this afternoon. I also just bought a 1997 Harley Davidson Heritage Softail, and a 1955 2 door Chevy Belair! Sorry to use the "C" word on a Ford forum..........lol I've been very busy! I will post pics later. Thanks again! -Bud
Lana Kane
