Dual Battery Setup
MOJIGGA
I recently hoooked up my dual battery setup, everything seems to work fine, but my gauge inside the truck is only reading about 9 or 10 volts.....this should be 14 correct? i attached a picture of my wiring diagram. can anybody give me pointers of why my gauge only reads 9 or 10 volts?
i have a 95 amp alternator, 160 amp isolator, a yellow top and red top optima. any help is greatly appreciated.
thanks,
Mojigga
M
MOJIGGA
found out, that i was running strictly off the battery. apparently my alternator was not charging them. now i either have them hooked up wrong, or my isolator is not working...
any suggestions?
yo  MOJIGGA,
1979 Ford Bronco, Correct?
If so;
Here is the 1979 Ford Bronco Wiring Manual (PARTIAL)by topsig at http://www.supermotors.net/registry/24302/78593
Clicik on each page's image or diagram to enlarge
page 5 shows factory duals depiction
page 8 shows wiring diagram for duals
he 4WD Systems Intelligent Isolators have been designed to meet all the needs and requirements of a dual battery electrical system in the modern 4WD vehicle. All models feature voltage and load sensing circuitry for switching plus inbuilt surge protection to prevent damage to other electronic equipment in the vehicle. The Heavy Duty model has an additional electronic circuit controller which has auxiliary load sensing to protect the alternator from overloading plus Jump Start capability from the dashboard. All models are simple to install and are water resistant.  Read More
http://www.4wdsystems.com.au/index.php?id=24
Dual Batteries Installation in a 79 F 150 (same as Bronco)
78/79's are easy. They have matching places for batteries. So I have one on each fender well.
The cable is the +12v from the battery to the starter relay (solenoid)
.https://lh6.googleusercontent.com/-dFgd9i7FI5M/TmlaYRO5kyI/AAAAAAAAJsU/HOACko4rm-Y/s912/DSCN4159.JPG
This cable is feeding the isolator going to the auxiliary battery
https://lh3.googleusercontent.com/-TYw5WAxfWZI/TmlaX_wyVJI/AAAAAAAAJsQ/sgd3y-JVE3w/s912/DSCN4160.JPG
This cable is going down to the starter
https://lh5.googleusercontent.com/-8aShN5aTsas/TmlaX0E8KbI/AAAAAAAAJsM/Cr5W7__CPzM/s912/DSCN4161.JPG
This is the +12v from the alternator.
https://lh5.googleusercontent.com/-i0jdjw-wt08/TmlabF8y5BI/AAAAAAAAJsc/WCeClfccOvE/s912/DSCN4163.JPG
The alternator wire goes to the mega fuse and the to the isolator. The factory uses a fusible link in there alternator wiring. I upgraded alternator to a 3g capable of 130 amps so I have a large mega fuse to protect the wiring. It connects to the same pole with the wire that came from the starter relay (solenoid).
https://lh6.googleusercontent.com/-yUrphxd9UUc/Tm1GbvpVqGI/AAAAAAAAJwA/2508Ei-nlB4/s912/DSCN4210.JPG
This cable leaves the isolator and goes to a mega fuse at the auxiliary battery.
https://lh5.googleusercontent.com/-Jn6NNlzILho/Tm1GfrBdeaI/AAAAAAAAJwI/wQvettaIW7c/s912/DSCN4213.JPG
https://lh4.googleusercontent.com/-nynmCwjQ8Jk/Tm1Gj77si7I/AAAAAAAAJwY/Ksg0W1gaUSQ/s912/DSCN4217.JPG
This wire is the auxiliary battery +12v to the mega fuse. I installed a fuse here to protect the cable/truck because of the length of cable and possibilities of something shorting the cable. In my opinion its worth the extra $12.
https://lh3.googleusercontent.com/-4aX66Bh80KQ/Tm1Gmpkky-I/AAAAAAAAJwg/S5hKQvWvg0Y/s912/DSCN4219.JPG
The winch cable is fed from the battery +12v cable on the line side of the mega fuse. This way it takes its power from the auxiliary battery when the engine is not running.
https://lh6.googleusercontent.com/-M2KIo9641RQ/Tm1GksikDEI/AAAAAAAAJwc/BNYU3vvfyZQ/s912/DSCN4218.JPG
better view of everything
https://lh4.googleusercontent.com/-g_rCnocVfAU/Tm1Gil_GcbI/AAAAAAAAJwU/hWzLBvUJBuM/s912/DSCN4216.JPG
From each of the battery negatives I grounded to the same piece of steel on the truck
https://lh3.googleusercontent.com/-eBFWhVqNICY/Tmlaj9kkHCI/AAAAAAAAJs0/2n5T8tCfQg0/s912/DSCN4169.JPG
Here is both frame connections
https://lh3.googleusercontent.com/-_U0piV0AZsI/Tmlafgr7GJI/AAAAAAAAJsw/lyOsvHMuqLA/s912/DSCN4168.JPG
https://lh6.googleusercontent.com/-bwnNnOr3tfY/Tmlak_F2FdI/AAAAAAAAJs4/fzo7gfFJ_NA/s912/DSCN4170.JPG
My old battery negative cable went to the engine block and because the new cables do not I ran a cable from the same piece of steel to the engine block to ground it.
https://lh5.googleusercontent.com/-y3pQfOsYWlo/TmlaoQG2FJI/AAAAAAAAJtA/tryXBpdHMG8/s912/DSCN4172.JPG
All that is left is the control wiring for the isolator. This is very easy. All you need is a +12v source that is hot when the key is in the run position. I used the wire that provided +12v to my reverse lights switch. The reason I chose it is its close and with my transmission conversion it was no longer used.
https://lh3.googleusercontent.com/-s9p_ZN0LmU0/Tm1GfhDIQJI/AAAAAAAAJwM/N1WyszJfp4E/s912/DSCN4214.JPG
The other side you just ground it.
https://lh4.googleusercontent.com/-ofvbWwbzoSA/Tm1GgEWECbI/AAAAAAAAJwQ/K6Uue9RJNIE/s912/DSCN4215.JPG
Now operation of this set up.
When you are driving/truck is running the isolator will close paralleling the to batteries together and charging both batteries at the same time. If you use a heavy accessory such as a winch while the engine is running it will receive the power of both batteries and the alternator will try to keep them charged.
If your engine is off like you trying to winch you dead truck on the trailer. The isolator will open and the auxiliary battery will carry all the load of the winch. The benefit to this is if you get the truck on the trailer and it kills the battery to do it. Now you have got home to where all you tools are and fix your truck. Your starting battery is still good and you can start your truck. Now the isolator will not close until the truck is running or you let the key turn to the run position because the ignition system when the key is turned past the run position to the start position cuts all unnecessary power. Once the engine starts and the key turns back to the run position the isolator will close and charge the dead battery.
by 79F150
Dual Batteries Installation Info & pics in a 79
Source: by axaviere (Truck) at SuperMotors.net
Wiring Diagram in a 79
Source: by Chilton
Dual Batteries Disconnect Schematic
Source: by Wells
M
MOJIGGA
Miesk,
im actually hooking up the dual batteries in my 1996 Bronco.
but this is good info.
my alternator wire goes directly to the isolator, and then two (+) cables which go to each battery.
i see in that diagram the alternator wire goes to the main battery and then to the isolator.
if i could figure out how to put a picture in this message i could show you my diagram of how its hooked up.
thanks for the info though,
-Mojigga
ok
To begin with this is as built;
from
Section 14-00: Battery and Charging System, Service
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
DIAGNOSIS AND TESTING
This is by Painless
http://www.painlesswiring.com/Manuals/40102.pdf
It is diff than the 4WD Systems Intelligent Isolator diagram I showed in prev reply
So, if you know the isolator brand, it will help id what diagram to use.
excerpt; "
Connect your winch positive power cable to the main battery. This is to allow the alternator to
power the winch along with the main battery when in mode two (2). Winching in mode two (2)
will hold the auxiliary battery in reserve for jump-starting. This is important if you stall the motor
or turn the key off after winching without allowing the main battery to recharge. Note: It is best
to run the engine 5 to 10 minutes after a winching operation to recharge the main battery.
Connecting the winch to the main battery is opposite from all other dual battery systems. When
using the Cirkit Boss Good Samaritan Dual Battery System you must connect the winch to the main
battery for optimum winch operation.
Stereos and Amplifiers
Connect your car radio and amplifiers to the stock, main, battery. This will allow the system to
turn off with the key. By connecting the stereo in this manner you will make sure that the stereo
will not drain the main battery by being left on accidentally when exiting the vehicle. Always
connect the stereo to the accessory side of the key..."
To post a pic from your PC, look below @
Attach Files
has a paper clip depiction to the left
Max. single file size: 750MB  Click on Choose Files find the pic you want to post...Have to go through this myself since we have an updated forum now/then Add Reply
M
MOJIGGA
Miesk,
why wouldnt this setup work for me?
do you have any ideas?
M
MOJIGGA
Miesk,
i have the Surepower brand.  and it doesn;t call for a ground from the isolator (only has 3 studs, 1 for the alternator, 1 for each battery)
its either the 120amp or 160amp, i can;t remember which.
yo M,
ok,
I looked up Sure Power
they say, "Up to 1998 and newer Ford Motorcraft alternator systems having the three wire plug connector. Call Sure Power Industries for a separateset of instructions and modification procedure for the two-plug alternator system that does not have an output bolt. "
Also see http://www.cooperindustries.com/content/dam/public/bussmann/Transportation/Resources/instructions/BUS_CBT_INST_180012q.pdf
See diagram on page 2
For ground; Intake Manifold to Block Strap Location pic in a 96
http://www.supermotors.net/getfile/727560/original/dsc_0505.jpg
by bossind
Also, fyi, "In 1996 Ford publicly recognized the fire hazard caused by the 2G alternator and released TSB 96214. This alternator design caused increased resistance and heat which could damage the wire harness and alternator. A small percentage of vehicles actually caught on fire!
Fords 3G alternator was a giant leap in technology and quality. The 3G was internally regulated, used two internal cooling fans, sealed bearings, and had a superior battery stud. The 3G’s were more efficient, and produced more amperage at idle than any of its predecessors."
Source: by Ryan M
3G Install Tech http://oldfuelinjection.com/?p=75 by Ryan M
M
MOJIGGA
Thanks Miesk,
you guys are awesome on this site!
one thing i have noticed in all these diagrams is they never say anything about the selenoid?!
i got wires running from the selenoid all over the place, to the alternator, starter, to the battery...
yo M,
yw
Solenoid... The unit mounted on passenger side inner fender near batty is described by Ford as starter relay
The unit atop starter is descr as the solenoid.
Here is the relay on my 96 Bronco 5.0 without any changes since new
Item Part Number Description 1 N805403 Terminal Nut 2 11390 Starter Solenoid 3 11A171 Seal 4 11130 Drive End Housing 5 N805405 Solenoid ***** (2 Req'd) 6 11001 Starter Motor 7 11135 Bushing 8 11A196 Drive End Housing Seal Ring 9 11005 Starter Motor Armature 10 11A172 Armature ****** Ball 11 11A167 Planet Gear Retainer 12 11K190 Planet Gear 13 11355 Output Shaft 14 11A165 Stationary Gear 15 11036 Pinion ****** Washer 16 N805404 Truarc® E-Ring 17 11067 Drive Lever and Pin 18 11350 Starter Drive 19 11180 Drive End Housing Seal 20 11223 Stop Ring Retainer 21 11222 Starter Drive Stop Ring 22 — Magnet Pole Piece (6 Req'd) (Part of 11075) 23 — Pole Shunt (6 Req'd)
(Part of 11075) 24 — Magnet Retainer (6 Req'd) (Part of 11075) 25 11075 Starter Frame and Magnet 26 11061 Brush Holder 27 11059 Brush Spring 28 — Bushing (Part of 11049) 29 11049 Brush End Plate and Bushing 30 N805406 Brush Plate ***** (2 Req'd) 31 N805428 Through-Bolt (2 Req'd)
