Anyone ever used these replacement hubs?
Edna, TX
Seeing if anyone has ever used these replacement hubs? If so, success or failures?
Thinking about trying a pair out. $50 is worth a shot to me... I think they'll match better aesthetically as well since I am doing new black wheels with new chrome center caps...
Btw, I currently have the old red **** top hat manuals...
Part 2,
Soillar-Parts carries replacement parts and accessories for all types of ...
I suggest that you avoid these hubs.
Suggest Warn®
Warn® Premium Manual Application Chart; Premium Manual Hub #20990; Premium Spindle Nut Kit #32720; Premium Hub Service Kit #20825 for 66-96 Bronco 19 Splines (Will Not Fit '87-Early '88 Models Vehicles, ****** Mount); 59-96 F 150, 59-75 F 250...Vehicles With Full Time 4WD Requires Transfer Case Conversion Kit; When Replacing Automatic 3 Hole Cap ***** Hubs, You Must Purchase Corresponding Spindle Nut Conversion Kit; Miesk5 Note, CONVERSION KIT P/N 32720 is for both Premium Manual Hub & Standard Manual Hub; "... Warn all metal Premium Hubs exhibit a long list of technical advantages no other hub can match. The external hub body is constructed of the practically indestructible ZA27 super alloy. Inside the cap assembly, wave spring technology is used to enhance reliability. Longer clutch-ring spline teeth and body spline area result in better load handling. Warn Premium Manual hubs feature a larger body wall thickness to optimize clutch-ring strength. Rapid positive engagement prevents ratcheting, dual dial seals lock out contaminants, and a corrosion resistant, chrome-plated finish substantiates our goal of never-ending performance..."
Source: by Warn®
Or Mile Marker
91BroncoPickup
Edna, TX
Yeah, I wonder why it says "✅ fits", but doesn't list it in the description?
I'll get them here, open, compare, then probably send back for some MM.
91BroncoPickup
Edna, TX
I got them in finally. Gonna look at them compared to the red factory tophats... If they match up, I might give them a shot anyway. Idk...
I'll update when I figure it out... I do like the Mile Marker look as well, just wanted something other than Warn personally... Everyone has those and my entire rig is different... So there's a theme I guess.😁
stevedave
