Alternative Engines
rdm
I am looking at a 95 EB that is in great shape but has no engine, but does have a transmission. The guy is asking $800 for it. If I bite, and dont want to put the windsor back in it, what are some other engines that will fit? I've also heard that a cummins will fit in it, but wouldn't mind having something pretty economic.
Rdm
Hi RDM..,
Changing engines, even fr. the same MFGR. can be a "bowl of snakes" (computer & all)
--unless you're a mechanic/engineer-- :unsure:
Just finding/getting the stock orig. eng. back in & all components working is a chore but, this is the cheapest/easiest. >:D< <'>
yo RDM,
WELCOME!
As Bob advised; it will be involved.
Look in my site for the diesel swap LINKs @ http://www.broncolinks.com/index.php?index=834
such as, for example;
Installation, 7.3L & 6.0L in Two 93's (owned by David C)
Source: by David K at http://www.dieselpowermag.com/features/ford/0810dp_1993_ford_bronco_powerstroke_diesel/viewall.html
Installation Information, 5.9L Cummins; "...A 6 cyl. 5.9 Cummins engine will fit in your full size Bronco, but if you have not already beefed up your front suspension you will want to do so. A minimum fix is a good set of air bags for your coil springs. Other options, if not already done, include a solid front axel or a heavy suspension lift. The full size Ford Bronco takes all of the same Ford Cummins diesel conversion hardware as the F Series Ford pickups of the same year..."
http://www.fordcummins.com/bronco-cummins-conversion.html
see more swaps
GL!
R
rdm
Thanks guys, sounds like its more trouble than its worth. What can you do with the windsor to get better fuel mileage?
"What can you do with the windsor to get better fuel mileage?"
Mount that puppy in a Nash Metropolitan..... :eek: /emoticons/[email protected] 2x" width="20" height="20" /> :lol: Just kidding..!
At the end of the day, an eng. performs best at a constant (if memory serves) 17:1 air/fuel ratio. As soon as you move the throttle pedal, that all moves around, & will settle back down at flat cruise.
The closest you can come to keeping it near there is fuel injection. OR, place an egg between your foot & the gas pedal.. :D/
These trucks are not aerodynamic, & are heavy.
nelbur
If he still has the original engine, take it, as you will need a core for a good price on a re-manufactured long block. If you will go with a junk yard engine the core will not be important, but the stuff bolted to the engine might be needed. Since your engine was already fuel injected, you would need a smaller engine to get better fuel mileage. The weight and aerodynamics are the main cause of the less than wonderful fuel mileage. I agree that it would be best to install what was in the truck originally.
Coastersfwb
