87 Bronco II Fuel pump not working
MasterPain
Fuel pump not coming on dropped the tank hooked the fuel pump up tp the battery and it ran does this mean it is good? Replaced relay ,had the module ,coil check and check the fuel cut off switch they are all good ? If any1 can help let me know. :((
M
MasterPain
:-Can someone delete this for me thanks >
rickco
i have a 1988 bronco 11 i am having the same problem can u tell me where the fuel shut off is u talking about
American Rebel
4x4 Trail Master
Chesapeake, VA
28986[/snapback]
I believe the fuel shutoff switch (inertia switch) is the same on a full size bronco.
Look under the console and behind the brake pedal, there should be a switch that has only two wires running to it....
Hope that helps :)>-
david@holycitytransportat
