help do you know whats wrong
muddinlate86
va.beach
i have a 86 ford bronco i just bought not long ago i have replaced the tie rods,wheel berings,and put new warn locking hubs in.when i hit a bump too fast my front end feels like its falling apart.the ball joints dont look bad a it stops when i slow down{alot}.i have 8 inches of lift and run 35x15.50r15 mickey thompson claws. i dont know whats going on does any one know what it is or had the same problem
Rob Yockey
Petaluma, CA (not by choice)
Can you discribe better what happens when you hit a bump? Is your bronco making a grinding sound, shaking, pulling to one side or the other, ect.? If you discribe the problem better, the pople on the forum can probably point you in the direction.
Thanks,
Rob
muddinlate86
muddinlate86
va.beach
Can you discribe better what happens when you hit a bump? Is your bronco making a grinding sound, shaking, pulling to one side or the other, ect.? If you discribe the problem better, the pople on the forum can probably point you in the direction.Thanks,
Rob
the front end dosent pull it just feels like its boncing up and down real fast as if i was driving over 5000 speed bumps in a row.but when i slam on the breaks and alomst stop its fine.
Rob Yockey
I would double check everything in the front end. Make sure that the wheel bearings are well lubed, check the ball joints, check the tie rod end isn't loose, worn or incorrectly adjusted. Good luck!
Rob
I'm not one of the good mechanics that are here. I have no experience with lifted trucks nor do I know what common problems they have. With that being said, it sounds like something is loose or broken (or possibly installed incorrectly). Unless it has something to do with your AntiLocking Braking system ABS. Does your ABS light come on?
When you discribe bouncing...
Is it like big discrete bounces? Like maybe you have a broken shock?
or is it more like a vibration, like you wandered off of the side of the road onto the shoulder where they had one inch deep cuts in it every two or three inches?
walnuts75
Ohio
How old are the shocks because it just sounds like your shocks are in need of replacement.
bidibronco
Norfolk Va
Souns to me like something in the front end isn't working correctly. Had to say it... just had to!
muddinlate86
muddinlate86
va.beach
thanks for the help guys the shocks are only a year old.they were put on when it was lifted.the bumps are like joe said if i wanderd off the shoulder and there were cuts in the road but a little more sever than that.its strange it only does it on some bumps.i hope someone knows something beacause its my daily driver and weekend warior!
thanks james
Big_Ford_POS
Smyrna DE
Well its sounds like you replaced most, It is probably in your best interest to replace the ball joints and check all your steering linkage. We have an 1988 f350 tow truck and the bushings where the two halfs of the axle meet are worn out. It does what we call the death wobble... After you hit fourth gear and about 35 mph it starts this crazy shake than you can slow down or put your foot into it and hang on until about 50 mph when it smooths out. Really man you might just have a bad lift or a combination of things... Also get a junker car cause if your bronco is your only ride than sorry for your luck. I have a 96 chevy lumina the best car ever. It with run forever on gas and oil. Check your bushings on the radial arms also you could have them overtighened or loose. Let us know of your progress...
Preach
West Branch MI
HI, We had this same problem with the new Ford 350. When we hit bumps in the road it would shake and bounce. The dealer said that the that the front axle shims were the wrong ones. Hope that this might help.
the shocks are only a year old.they were put on when it was lifted.the bumps are like joe said if i wanderd off the shoulder and there were cuts in the road but a little more severe than that.its strange it only does it on some bumps.thanks james
Again I have no experience with lifted trucks.
It sounds to me like you need to differentiate between
1. body/frame issues
2. steering including ball joints
3. axel /hub and wheel
4. ABS
Working backwards..
4... ABS if you pull the fuse #10 that should disable ABS. Without ABS your truck will still stop as though with regular brakes.
3.. are your wheel lugs tight?
How long after you installed the new hubs did the problem start?
There is a universal joint between the hub and the axel on each side. A bad universal can give a vibration, more so when there is a load on it. They are disengaged when your hubs are disengaged.
2. ball joints. I need to do mine. I am told it is a full weekend job, or costs about $1200 in a shop. Do you know how to check your ball joints for play?
1. IF it is a weekend warrior, you might want to check your shocks, even though they are relatively new, could you have banged them real good?
I don't know about brackets and bushings and stuff.
The real mechanics usually get on here after dinner.
joe
muddinlate86
muddinlate86
va.beach
i will check this out thank you guys so much i will let you guys know what i find out and help who ever i can
thanks
muddinlate86
muddinlate86
va.beach
thanks
B-150 Mudder
Brucville, Indiana
Do you have a steering stabilizer on the front of the truck? If so is it in good shape? I would try, if you have one, unbolting one side and push it in and out and see if there is any resistance. I am running 35's on my dodge and I have to replace my steering stabilizer because the stock stabilizers can't hold up to te abuse that a 35 puts on it. I am upgrading to a dual stabilizer which is what I would recommend for you to do if you plan on going bigger than 35's anytime in the future. Let me know if it helps?
muddinlate86
muddinlate86
va.beach
Again I have no experience with lifted trucks.It sounds to me like you need to differentiate between
4. ABS
Working backwards..
joe
thanks joe. my lugs are tight and its not the hubs i had the problem before i replaced them.ball joints arnt that much and you can do them your self with the help of the advance auto ball joint loaner tool.doing it yourself saves alot of cash and its good experiance and it only takes about a half of a devoted day to do them.if you do them your self make sure you get the heavy duty ones they slide in a little better and last longer
muddinlate86
muddinlate86
va.beach
thanks b-150. i just checked and there good i do have two stabilzers with a custom setup frome my offroad shop beacase of my lifts
B-150 Mudder
Brucville, Indiana
Good deal glad you have that setup. I found that the steering stabilizer is really important when I tried to apply the brakes and the front wheels started turning back and forth and ripped the steering wheel out of my hands. Sorry I couldn't help more. Good Luck with it.
I'm waiting for better weather, but thanks for the tip.
Oh yeah... It seems that I always have to calculate some extra time for murphy's law stuff.
Sorry my suggestions didn't pan out (if you checked them all already) as I said the guys who know their stuff are usually on a bit later.
Good luck, I hope you solve your problem.
When you do figure it out, please post the solution here, so I and others can learn.
Thanks
joe
love_my_bronco
Spokane
Probly way off but did you say 35-15.5-15 thats really wide it could be you tire tread hitting ******* something underneth. i dont know what lift you got so im not sure it just sounds possible.
