Hey Mike, without a pict, the best I can come up with is those sound like the pins to drive the turn signal cancel cam. They should lock into a slot or hole so the plastic ring turns with the wheel to kick off the signal switch on return. The horn\cruise contacts are the 2 that are on springs but don't move around. (If that makes sense)Every time I try to move forward I have another question.
I am having a hard time even knowing how to word this question. There are two spring loaded pins that I think are electrical connectors that are located in a circle very close to the steering column and they are both on the same diameter/circumference and they spin freely and separate from the turn signal switch. One is copper colored and one is steel colored.
There is also a key-way on the backside of the steering wheel that aligns on the same circumference as these pins. It appears to me that when I install the steering wheel that one of these pins is going to fall into the key-way the first time the steering wheel is rotated.
Am I supposed to align this in any particular way when I install the steering wheel so that one or the other pin is in the key-way??
I think that this may be the connections for the cruise control?
Hope that helps
