Need parts Please help
littlejarv21
Sheridan wy
89 through 91 F-150 250 350 and bronco E4od trucks I need the shift linkage For the tranny and transfer case I don't care what it comes out of it just has to have an e4od And has to be a 89 90 or 91 With the transfer case Honestly the part I need most though is the rod that shifts the tranny I'm doing a conversion In my 86 F150
Yo littlejarv21,
See https://torqueking.com/category/ford
●1986 F Series & Bronco ELECTRICAL & VACUUM TROUBLESHOOTING MANUAL (partial) by Ford via 1986 EVTM - Gary's Garagemahal (the Bullnose bible)
1985-1986 Fuel System Adjustments by Ford via Gary
See more info by Gary.
1986 Bronco Operating Guide @ 1983 Ford Bronco Manuals & Pamphlets (Scanned) picture | SuperMotors.net
1980-86 Pickup Fasteners by Ford via Gary, but mostly for front clip
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf. via BroncMom
Sorry, somehow I overwrite this;
"For a YARD SEARCH on-line, I use;
Can select a certain part.
If a specific part isn't listed, search again for the next higher assembly such as Search: 1991 >Ford > Bronco > Transmission > Transmission > 03311 At, E4od, 8 302 (5.0L) or transfer case
GL!
pltommyo
Michigan
Weller in Grandville, MI has a 1991 F150 4WD with 5.0L and E4OD transmission. Last time I was there it was pretty complete (two weeks ago) when I took a few engine bits.
Lana Kane
