Need parts Please help
littlejarv21
Sheridan wy
89 through 91 F-150 250 350 and bronco E4od trucks I need the shift linkage For the tranny and transfer case I don't care what it comes out of it just has to have an e4od And has to be a 89 90 or 91 With the transfer case Honestly the part I need most though is the rod that shifts the tranny I'm doing a conversion In my 86 F150
Yo littlejarv21,
See https://torqueking.com/category/ford
●1986 F Series & Bronco ELECTRICAL & VACUUM TROUBLESHOOTING MANUAL (partial) by Ford via 1986 EVTM - Gary's Garagemahal (the Bullnose bible)
1985-1986 Fuel System Adjustments by Ford via Gary
See more info by Gary.
1986 Bronco Operating Guide @ 1983 Ford Bronco Manuals & Pamphlets (Scanned) picture | SuperMotors.net
1980-86 Pickup Fasteners by Ford via Gary, but mostly for front clip
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf. via BroncMom
Sorry, somehow I overwrite this;
"For a YARD SEARCH on-line, I use;
A yard that uses Hollander Interchange can search other yards and have it shipped including some Canadian yards.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @ Seller Directory | Used Auto Parts | Hollanderparts
Can select a certain part.
If a specific part isn't listed, search again for the next higher assembly such as Search: 1991 >Ford > Bronco > Transmission > Transmission > 03311 At, E4od, 8 302 (5.0L) or transfer case
GL!
pltommyo
Weller in Grandville, MI has a 1991 F150 4WD with 5.0L and E4OD transmission. Last time I was there it was pretty complete (two weeks ago) when I took a few engine bits.
