window key for rear
bluefordcat
SOUTH DAKOTA
94 bronco, how would I go about getting a key for the tailgate to operate the rear window ? I only have a ignition key. It would be nice at time to walk up an roll the window down
Well, I guess the short answer would be to call a locksmith.
*old fart story alert*-- Once when putting in a suspension lift on one of my 78/79's we were using a friends garage about 45 min from my place. We finished it on the second day but I hadn't thought we'd get that far so I didn't even bring my keys with me & it would have been a better than 90min round trip to get them. While we were contemplating our delemma a friend of a friend showed up & lo & behold he just happend to be a locksmith. He had a number of Ford, GM & Mopar blanks on him and while we watched he took a Ford blank and wiggled it in the ignition cylinder. Took it out and looked at where the scratches were and started in on it with a small hand file. After doing this two or three more times he put it in and damn if it didn't turn in the cylinder and fire the truck. It took this guy less than 15 minutes to file a key from a blank by doing nothing more then jiggling it in the cylinder and looking at the scratch pattern. I went out a week later and had an alarm installed.
Locksmith or new lock B)
My ignition system has a disable on it and won't start unless you can figure how I rigged it. Crank all you want, it won't start :D /emoticons/[email protected] 2x" width="20" height="20" /> , but then there is also the tow truck or flat bed to contend with :-& . I guess nothing is theft proof :( /emoticons/[email protected] 2x" width="20" height="20" />
Yeah, but when you DO start it after all that cranking there's so much fuel in the exhaust the muffler it winds up looking like a beer can with a firecracker in it <grin> but the BANG usually gets people's attention.
Yup, I've always been a fan of the killswitch. I usually disguise it as one of the off-road light switches or use a microswitch tucked into the ashtray or up under the dash. It won't keep someone with a flatbed from dragging it off but that's what the Lojack is for.
I discovered a killswitch in my very first car, used to LOVE flipping it off for a couple seconds when going under a bridge & listening to the *bang* when I flipped it back on & it backfired. I kept leaving it off for a few seconds more & a few seconds more until one day I blew the freaking muffler right off the car & had to drag it home sparking & grinding the whole way. I guess some of us just learn best thru experience.
as Seabronc advised
or get the lock cyl and key from our SPONSOR; Jeff's Bronco GraveyardTailgate Lock Cylinder; Item #34525 - New
1980-96 Bronco Our Price: $32.00
and diy;
by Steve - "Tailgate Window Switch
The switch is actually 2 SPDT microswitches which aren't designed to be separated from the harness. They're riveted to the casting that slips over the lock cylinder, with a cover plate on top..."
Coastersfwb
