why no threads on big block swaps ?
sostahoe
I couldn't find any threads on anybody doing big block swaps. I am wondering if it has been done ? what was the result ? are there kits? or is this just a dumb idea ? I have a tired 71 302-3spd and a fresh hipo 460-c6 with transfer case gathering dust. any feedback would be appreciated.
ricks73eb
little chute wi
very heavy! and if your offroading it....prob not a good idea..
HOWEVER!! i have seen it done and holyshit that thing ripped!! but its a pain to get it to work in there the rad clearance is bad enuf with a small block.. not to mention headers and clearance 4 the master....
S_bolt19
Colorado
Like Ricks73eb said, very heavy. I have seen 3 460s in EBs and I have a friend who is building a Hi-Po EFI 460. The main thing is that you have to change everything in the running gear. The D44 isn't really strong enough for that kind of power and unless you keep your foot out of it, you will be twisting light duty axles in half every time you touch the gas in a binded or torqued situation. Most of the ones that I have seen with that big of an engine/type of power all have 1 ton or bigger axles. Lots of fabrication and when you can just slide a 351 in place of the 302/289, that makes those swaps a lot simpler.
Similar threads
T
Replies
Views
2K
Top stories on BroncoZone.com
T
T
Replies
Views
892
T
T
Replies
Views
2K
T
T
Replies
Views
1K
T
eholt80
