what to expect from a cam ?
Elmo
Forsyth Georgia
I am building a 351w speed density engine for my bronco. Maybe i should be but I am not looking to go MAF. Haveing asked some friends with experience on both sides (MAF/SD) i have narrowed it down to two flat tappet possibilites for my cam selection. The block will be bored 30 over (pistons to be decided) gt40 heads 1.6 roller rockers and an edelbrock performer intake. Now for the undecided part which cam to go with ? It has been recomended to use one of these ;http://www.summitracing.com/parts/cca-35-255-5
or http://www.summitracing.com/parts/crn-444232
Am i on track or is there a different choice. Please advise.
yo ELMO,
Overview, Bronco & trucks, vans, stangs, etc.
Source: by Ryan M (Fireguy50) at http://www.oldfuelinjection.com/?p=9
How to pick a CAMSHAFT for EFI by Ryan M (Fireguy50)
Good 5.0L/5.8L (302/351) EFI hydraulic flat tappet cams:
Comp Cam 35-255-5 (YOUR SELECTION!)  http://www.summitracing.com/parts/cca-35-255-5
* Duration at .050 in.: 210 / 214
* Gross valve lift: 0.478 / 0.485
* Lobe separation: 114°
Edelbrock 3782 (http://store.summitr...p?part=EDL-3782 )
* Duration at .050 in.: 210 / 216
* Gross valve lift: 0.469 / 0.484
* Lobe separation: 116°
Crane Cams 444232 (http://store.summitr...part=CRN-444232)
* Duration at .050 in.: 206 / 214
* Gross valve lift: 0.448 / 0.464
Best 5.0L/5.8L (302/351) Roller EFI cam:
89-95 Mustang 5.0L ** (http://fordfuelinjec...0Lcam-specs.jpg)
Ford Part numbers: E8ZE-6250-CA / F1ZE-6250-AA / F4ZE-6250-DA
* Advertised Duration: 276 / 266
* Duration at .050 in.: 214 / 210
* Gross valve lift: 0.444 / 0.444
* Lobe separation: 115°
b]Best 302/351 EFI roller cams[/b]:
Can be found on eBay or Mustang forums cheap
Several 1993-95 Gen 1 Lightnings going 11 sec 1/4 times
Good idle, good torque
a reply by SMOOTH; "...
Comp Cams 31-255-5
* Duration at .050 in.: 206 / 212
* Gross valve lift: 0.462 / 0.474
That's the cam I put in. I like it, it works well with my GT-40 heads and I still have a good idle. I recommend itLinkbar lifters can be used to retrofit a roller cam into an older block..."
EFI Performance Upgrades by Ryan M (Fireguy50) http://oldfuelinjection.com/?p=9
GL!
kyleh01
