water pump bolts
defiant
New Jersey
Water pump let go! Started replacing broke two bolts lost my german temper!! Back on it today realized i made another mistake by not marking bolt length. Can any one tell me bolt lay out by length!on 5.8 Thanks
Bronc76
Bolt, 5/16"-18x5"
Stud, 5/16"-18x 3/8"x 16 x 5 3/8"
Stud, 5/16"-18x 3/8"-16x 3 7/16"
D
defiant
New Jersey
Thank you for your input,I pulled the timing cover today,i will pull those broken studs sat, then check or change the chain and gear,start the rebuild! i will let you know how i made out Thanks DEFIANT
When you start pulling the broken bolts, work them back and forth like you would a thread cutter. Start in the tighten direction and then back, an old trick taught me by an aviation mechanic and it has done well for me over the years. The ends are usually corroded and doing that will knock the crap off the end of the bolts. That has worked for me on any sticking bolt I've come up against. First it breaks the corrosion weld and second, especially if it is a ***** you are trying to get out, it keeps from messing up the surface you need to press against to get the ***** or bolt out.
Staff online
