washed out rings
rogmit
a friend of mine told me he thought when my coil burnt out it could of washed the rings out due to the coil going bad, is that possible because other than the rough idle it still has pickup on acceleration--and if that's poosible, is there a recommendation on where to buy a beefier than stock motor
wrachet
Kansas City Area
Dang...LOL...That's got to be the "strangest' thing I've heard yet! Next time you see this friend of yours...tell him he dropped his pocket.
Good luck getting even!!!
Colleen
bluesman17
Spam Terminator
South Bend, Indiana
Have it rebuilt, it would be cheaper/same price as buying a whole different one and this way you can have "creative control" over what goes in it and whatnot
stubby
Prairie du Chien, WI
explain to your friend it was only the blinker fluid that was low or even the muffler bearing went bad.... as far has the running rough... check timing or the plugs- your coil did go bad i assume??? if you cranked it over alot, you might have fouled a plug or 2
hfrost112
