ShadetreeSeattle
- Joined
- Feb 21, 2017
- Messages
- 61
- Reaction score
- 44
got a bronco here that's baffling me. it has several issues which are an annoyance, at best... but alas, i'd like to try and gather some collective ideas on the subject, or at least some pointers on where to look for electrical troubleshooting. at this moment i believe it to be an electrical issue of some nature, as i have tested or replaced a bunch of stuff on this rig. (fixed a bunch of other problems, but never could shake these three as of yet) sorry if this is a lot of info, but i have been trying at this one for a while. i can split these into separate topics too, but thought they might be related.
1989 ford bronco, 4.9 inline 6, c6 automatic transmission, no fancy stuff done to motor besides a reseal/cleanup on the top end, vaccum line replacement everywhere and removal of air injection and a/c due to components being end of life. (yes i capped everything and whatnot, emissions is not required in my area) throws no codes except the air inoperative code... (it's how you know the computer still has a pulse. haha)
three possibly interconnected symptoms
computer related? well i tried another junkyard computer and it has the exact same symptoms across the board, except far more exaggerated than with original, which is odd, but shows it's perhaps not a dead computer)
problem 1) possibly electronic ignition related slow crank
it sometimes when warm/driven for a duration will have problems restarting. when it has this problem it seems like the battery's dead. (cranks slow, lights sort of dim, etc) but it's actually not starter related whatsoever, from what i have at least gathered so far. i believe it to be ignition related, as it turns over just fine with the ignition module unplugged (accidentally discovered this by forgetting to plug back in while testing), but then with it plugged in it seems to light the plugs well before T.D.C. as it literally fights the starter, creating a slow crank condition, which ran the original battery dead several times. so i put in my truck's three year old agm battery in it and it now can crank for a while without running dead. sometimes if i turn back off the ignition and re-try it works just fine. like nothing's wrong at all. other times i gotta let it sit for a while and cool down.
observations/things i have tested:
seems to happen when warm, (checked iat/ect and well within values)
at random, but more often after it was sitting for 2+ minutes (fuel injector? rail pressure test seemed to show no sign)
timing is on point, 10deg. before tdc spout disconected
timing light shows computer is advancing like it should when spout connected and throttled
distributor replaced and module too (stupid distributor-mount type)
wires replaced and routed away as they can be from eachother
tried a known good maf sensor from another inline 6. no change...
computer throws no codes except the 54 or whatever saying that the air injection is inoperative (removed capped etc. because it was shot)
problem number 2) random stalling while shifting into drive or reverse from park
it does it more often than not when warm and only does it when shifting from park to drive or reverse (into a gear) and especially if i'm turning the steering wheel.
psp switch works... atleast it doesn't throw a code on koer tests.
transmission range switch was shorting out so i replaced that... (it's a c6 auto and it has the range switch has the extra 2 wires that go to the computer as an idle up signal)
iac ports nice and clean as i had the intake apart when resealing the top end.
tried multiple iac valves with no difference in operation... also clean and when you push the valve with a pokey tool it moves freely
problem number 3) surging while under load
does it no matter what temperature engine is at and surging frequency is manipulated by how much gas you are giving it. the more pedal, the higher the frequency. if you lay into it, the frequency goes high enough it's less noticeable. at higher engine speeds it's less noticeable or not at all like when going down the freeway for instance. most noticeable when at a light throttle or acceleration at a low speed.
it feels like you are lifting your foot completely off the pedal for a split second, then goes back to where it was.
tps looks great on my fluke with the simulated analog bar graph
fuel pressure is nice and hi in the 45-55 range.
rear pump and tank replaced cause it leaked/sender was shot
FPR seems to do it's job/is not leaking into intake
possibly computer related? well i tried another junkyard computer and it has the exact same symptoms across the board, except far more exaggerated than with original.
i'm at a loss! haha. i'm going to try and live monitor stuff as i drive down the road by setting the multimeter against the windshield and running leads to test stuff like tps output, egr valve solenoid, iac valve, etc. to get a better idea of what's going on. thanks for reading! drop a line if any of this rings a bell.
