Speed Density
af ford able
I WOULD LIKE TO ADD A CAM TO MY STOCK REBUILD 302 IT IS A 1990 F I50 REG CAB /SHORT BOX/ 4BY 4/ 302 V 8 /5 SPD WITH SPEED DENSITY IS THERE A CAM OTHER THAN STOCK WHICH WILL WORK WITH THIS SETUP . OR WHAT KIND OF CAMS ARE YOU GUYS RUNNING WITH THIS SETUP ALSO I WILL BE USING A FLOW MASTER FORCE 2 AND A K+N FILTER THANKS FOR THE INFO .
edelbrock makes a good cam for the 302. it doesnt matter what the rest of the truck is the only thing that matters is the year of the 302.
squatch23
Back
