Snorkel
bigbad79
ok i know exactly how to do everything except mounting the snorkel to the carb. i dont have one of those old air cleaners to weld closed for a seal all i have to work with is a truck avenger carb so any ideas on securing a PVC elbow on top of carb? testimonials, pics, links, anything!
Broncoholics
Broncoholics
Washington State
If its a 90 deg elbow, drill a hole on the top to allow a longer rod to come up thru to help hold it down. Use a rubber seal around the base of the pipe connecting to the carb.
bigbad79
thats a good idea the only problem is finding PVC to fit the top of the carb. its not a easy 4'' but 4.25 or 5 1/8'' so it wont sit properly over the carb. but really good idea. i wanna try and do something with that in mind
Broncoholics
Broncoholics
Washington State
What about those rubber Ferncos (I thinks thats the name) they have a hose clamp on each end and have different sizes to fit to outer diameter of PVC pipe. Your carb might be close to one of those sizes. You can find these in any hardware stores or pipe supply joints.
Another idea is to pvc glue another larger pipe around the end of the inner pipe that is slightly too small. Pipe supply stores will have more options than a Hardware Store.
davids78bronco
fabricator extraordinaire
central Oregon
make your own air box. It's not that hard. Top and bottom lid, from a 9" open element air cleaner, some sheet metal, to close it in, and the "snorkel" fitting
Got pictures of yours?
bigbad79
good ideas guys. i think i'm best off makin my owns airbox, seems like i cant get anything to sit on top of my carb the way i want it to so i'll just use a normal carb base and buils off that
Sufferedformula
