shocks and springs?
90bronco86
deltona Florida
Ok so I figured out my shocks are going out on my drivers side, my buddy has an f250 of the same year and he has brand new shocks and springs all the way around, could I use his shocks and springs on my bronco? And would it make any difference In height or ride?
yo, I just bought Bilstein shock for my 96;
Their on-line catalog is ez to use and saw that for the the 4600 Series shocks (NO LIFT, Single shock set-up);
90 5.8 Bronco uses same front shock as a 90 F 250 5.8
I was surprised!
However; rear shocks are different part numbers
You can also verify by looking @ your 90's Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate)
Door Jamb Label (Certification Label, also referred to as the Patent Plate, Data Plate & the Warranty Plate) pic in an 88
Source: by Jem270 at SuperMotors.net
look in lower right Under SPRING; B Z;
B (Coil) Z (Rear Leaf Spring)
And Ford does list diff spring in their MC On-Line Catalog @
http://www.fordparts.com/View Image
5310 Front Spring
Spring code C (Front)
5310 Front Spring
Spring code G (Front)
5310 Front Spring
Spring code U (Front)
5310 Front Spring
Spring code V (Front)
5310 Front Spring
Spring code B (Front) $214.60 Select a dealer for their prices and availability
5560 Rear Spring, Spring code Z (on page 5)
Then compare the F250 there for Codes
I'll post this for now
Coastersfwb
