Betty The Bronco
There is a paint out on the market called "HAMMERTITE". (Or something close to that). It comes in a spray can in a few different colors. You spray it right onto the rust and it somehow chemically reacts to slow down the process. I use it on our tow truck at work, (has a half million miles on it), and it slowed the rust WAY down. Both Lows and Home Depot have it and its not very expensive. Painted the whole chassis of my bosses plow bronco and it worked great on that. Hope that helps./emoticons/[email protected] 2x" width="20" height="20" /> I just had my bronco for just over year now, and a proud owner I am. But, it seems every time I go to wash Betty, my truck, I seem to find another spot of rust just expanding outwards like cancer, and don't even start with me about my back fenders (major rust HOLES)
/emoticons/[email protected] 2x" width="20" height="20" /> . So my question is how do take care of this problem in the most efficient way possible? I am only a high school student and my weekly income is right above minimum wage. Plus I don't know much about vehicles or body work for that matter. So if someone could help me out with a somewhat easy method that would be greatly appreciated. INCLUDE LINKS IF POSSIBLE PLEASE.
The only way to deal with this rust is to cut it out. As soon as cancer spots appear on the Bronco it is already too late. The panels on the bronco actually rusts from the inside out. So by the time cancer spots appear, a great deal of oxidation has occured and you MUST cut it out at least an inch away from the rust spots. A lot of sand, dirt, grime, and salt become stuck in the space between the rear fender and the rear wheel housing causing the inside to rot out first. Also, in order to determine how much metal has been rusted out, tap around the infected areas with a hammer to see how brittle the surrounding areas are. If any of the metal cracks or easily bends, you have to cut it ALL out. Usually it will be worse than it looks so be prepared./emoticons/[email protected] 2x" width="20" height="20" /> I just had my bronco for just over year now, and a proud owner I am. But, it seems every time I go to wash Betty, my truck, I seem to find another spot of rust just expanding outwards like cancer, and don't even start with me about my back fenders (major rust HOLES)
