Replacing Engine
snowman74
Oklahoma
Howdy all,
I have priced around for the machine work, and decided I'm just going to buy either a short block or a crate engine to replace my 5.0 302 EFI. Was hoping to get some suggestions from you guys on what I could get to basically drop in. I don't want to change out the tranny (4 speed manual). I'm not looking to go too expensive, I want to stay fuel injected, and I don't want to go up to a 460. Any ideas would be appreciated...especially from somebody that has replaced their late model bronco engine. Thanks!
Snowman74 :)>-
If you don't want to make any changes, go with a 5.0, even a 5.8 would require computer changes.
other than a yard engine; Ford Reman is an option; about $1,669.61 EA or long block
LARGE PDF FILE WARNING - DO NOT OPEN EITHER CATALOG BELOW UNLESS YOU HAVE CABLE or A HELLUVA LOT OF TIME TO ****
Remanufactured Engines & Transmissions - Motorcraft
thanks Seabronc; I forgot that the file is that large - I'll edit the post now to warn others too! >
snowman74
snowman74
Oklahoma
Thanks guys. But you know, I'm tired of speed density fuel injection. I want to go maf. Does that open my options up any? I understand I'll have to buy a new EEC. I'm also wanting to upgrade cam, aluminum heads, and possibly hyperutectic pistons. I don't want to go too much over $4000-$4500 to do this. I've been looking at new trucks, and thought, ****, for a third of the price, I could just get the old beast running smoother. She's barely broke in anyway LOL.
If you have other suggestions, I'd sure love to hear em.
Thanks,
Snowman74
snowman74
snowman74
Oklahoma
Thanks Yardape. I had actually been looking at that same engine (the GT-40). Do you guys know if that will mate up to my tranny? I might just call them tomorrow.
Also, what is the way to figure out which tranny I have? Do I need to use VIN to look it up? Where? Thanks again!
No matter which tranny you have, it is a small block tranny so it will match up to any 302.
Yardape
Alberta
One thing to consider, I assume the GT-40 will come with the 351w firing order. I am still at a loss as what to do to solve this problem. The only locical solution to this that I can come up with is use a computer from a 351w truck. I would also consider a C-6 transmission for this swap also.
Yardape
Alberta
I just noticed that you have a manual transmission so disregard my C-6 statement
Yardape
Alberta
You will have to get the correct computer, same as what I said before. Will bolt up to the tranny no problem.
snowman74
snowman74
Oklahoma
I've done a 180. I'm still going to be building up a new engine, over time...but for now I'm just going to do some work on my old 5.0.
I've decided to go with a mass air conversion kit. While I'm doing that, I'll have the upper intake off for other repairs as well. Anybody have any suggestions for some low-mid budget upgrades while I've got all that stuff off? Any tips or tricks on the upper intake manifold removal/installation?
Thanks all!
Snowman74
kyleh01
