removing pushrod from old master cylender
77bronco77
hey, i feel really dumb here but i took off my old master cylender and am replacing it with a new one. but for some readon i cant get the pushrod out of the old one?!?!?! i took the whole assembly out, and apart, and CANNOT get it out? anything would help. thanks.
also, do i need a steering wheel puller to take my old steering whell of??? a got a nice grant one :) /emoticons/[email protected] 2x" width="20" height="20" />
thansk
S_bolt19
Colorado
Yes, you have to have a steering wheel puller to take the old wheel off, they are on there pretty good. As for the push rod, it has a retainer clip in there that will probably get mangled when you pull it out. It really isn't needed because once everything is hooked up, it wont fall out, so you can just pull it out and go.
77bronco77
alright, where can i get a wheel puller? is it rentable?!?! and i was trying to get that stupid thing out still but still cant get it. yah it really doesnt look like its needed but if i can ever get it out ill try to replace it...can i just pull on it REALLLYYY hard and get it to pop out? or what can i do to get it out? thansk
STLKIKN
Calgary Alberta
77, you should be able to "borrow" a wheel puller from your local auto parts supply house, many have rental programs.
As for the brake rod... push the nylon grommet out of the hole at the pedal end of the rod, clamp the m/c in a vice, put a bar or extension through the hole and pull.
If that doesn't work for you, while still using the extension or bar, hit the bar with a hammer, the rod should pop right out.
S_bolt19
Colorado
it is there for a reason tho, try and replace it if you can
Yeah, its there to **** you off :blink: New MCs don't come with the rods anymore. The first time I replaced my MC, I finessed that thing out and the clip got bent. I massaged it back to form and put it back in. The 2nd time I had to replace the MC I pulled that sucker off and pitched it. All it does is keep the push rod from coming out easily. Now if you have enough play in your brake/clutch assembly to pull the push rod out, then you need to replace or rebuild the assembly. There isn't (or should not be) enough forward/rearward movement in the pedal to pull that rod all the way out. They are long enough that when everything is connected it cannot be pulled out. Like I said, that little clip is a pain in the A$$!!
77bronco77
yah i hate that damn thing. i finally got it out all buggered up and i got it in the new one. everything so far so good. just need pads and rotors now =]
eholt80
