now the update.
bypassed the safety switch. despite what some of my posts would lead you to believe, i felt i too, was smart enough not to close the tailgate with the window up. makes trouble shooting the rest of the circuit easier.
it wasnt the safety switch. unplug the lead coming out of the keyswitch going to the motor, test it 11.86 volts. huh? jump a wire from a spare battery into the motor side, motor runs. huh?
get the meter on them, each passes continuity checks.
both sides of that plug tested good yet when you plugged them together, nothing. so after spending way too much time figuring that out, at least everything in the
"how to fix your rear window motor" post about repairing the plastic dowels in the motor went smoothly. for the most part. had a bit of a problem getting it all back together with the two nuts stacked on top of each other. the pieces that broke left a surface which the bottom nut just wouldnt sit flat. i ended up having to put the first three in and then start the gear back in. once it aligned with the bottom nuts there was just enough room to slide the second nut in. with a small flathead you can wiggle them into place. theres probably an easier way, im sure someone will post it.
i can now operate my window from inside or out, and i dont have to crawl in the backseat to get something out of the back. which is good cause the door always manages to close when i get back there. thanks seabronc for the wiring diagrams made it that much easier not having to figure out what was what. broncozone bailed me out.
