Rear-end swap
Straight6
83', 300/4sp Rug, 3.5 ratio 9" w/autolocker in the rear, and the front is a TTB w/LS diff.
My rear axle housing is bent and sense I don't wheel this Bronco I would like to replace it with an modern 8.8 from a junk yard, is this an easy swap and can the disc brakes be used on my stock Bronc?
Yes it will bolt right in , There are conversion kits for the 8.8 to disk look in the back of petersons 4 wheel and youll find a company there selling the brackets and rotors for like $265 . The only other thing your going to run into is the driveshaft the 9 inch has a yoke and the 8.8 has a ****** . :D /emoticons/[email protected] 2x" width="20" height="20" />
Stubby1971
prairie du chien, wi
There is a company called SteelTech Solutions Inc- They are out of Marion,IL- I have a disc conversion on the back of my 90 full size with a 9"- it uses 1985 cadillac rear calipers and I think the rotors are from a 1985 lincoln mark 7- I'm not sure of the rotors but I know the calipers are rite- the phone # 618-997-4238- This company sells brackets and all- there is another company called Master Power that I used on my Barracuda, but I have no info for them
S
Straight6
If I can find a late model rearend with disc on it aready will it bolt up and can I use those discs?
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
2K
T
Coastersfwb
