jlb
Hello everyone my issue is my temp gauge will float back in forth while driving and top radiator hose will collapse like it's being squeezed and no heat my bronco is 1990 with 351 here is what I've done over the last six months.I had the coolant flushed changed the radiator, temp sensor,thermostat,new gauge,hoses,Water pump about a yr old.I have checked for the basics for blown head gasket like oil in the coolant dont smoke does have a little mis in it while idling And not losing coolant from what I can see.I took it in for the coolant flush and the mechanic told me it's possible its the head gasket because it was boiling as he was re-filling it.I can let the truck idle for an hour without it overheating until I drive it then the gauge will read 250 then back to 190 and proceed to do so while driving,any ideas I'm at a loss here any tests I can run or info would be great.
