sbveenker
- Joined
- Nov 27, 2006
- Messages
- 34
- Reaction score
- 0
So i have one or two little rust spots that are starting to poke through. What should i do to prevent them from getting worse? is there an easy fix?
yo!So i have one or two little rust spots that are starting to poke through. What should i do to prevent them from getting worse? is there an easy fix?
yo!Been fighting rust since day 2 due to road slat and beach sand sandblastin'
1. rust is larger than seen on surface, so be prepared to deal with once you begin; found POR 15 or Rust Bullet are best over-all rust inhibitors / paints (POR15 needs top coat(s) of paint due to UVs; RB is UV resist...
2. Some use patch panels avail at body shops or in major catalog incl Broncograveyard; LMC, etc.
where are the spots?..1/4 panel fender lips?..if so, we grind em out to clean metal, use RB and paint..prob area there is at seam betw inner fender liner and fender; water gets in there and begins the Bronco weight reduction process.
other replace entire 1/4 panel or tail gate.
some great repairs by many owners are listed in my site;
Panels:
http://www.broncolinks.com/index.php?index=432
1/4 panels..some with adhesive in lieu of tack-welding!
http://www.broncolinks.com/index.php?index=459
tail gate replacement
http://www.broncolinks.com/index.php?index=478
GL!
