does anyone know if my driveshaft angles will be messed up if i go from a 6 inch lift to a 9 inch lift? i actually wanted to go for a 2'' coil spring block under 9'' coils from JBG and since i already have 6'' leafs out back i'd go with a 3 or 4 inch block to keep things level. does it seem like it would work out anyone? its in preperation for 44''s. i also am considering cut out fenders to help with clearance issues but needing new driveshafts or having to re-set pinion angles is what i'm worried about
