leveled bronco
bill.lane
i installed a set of 1986 f-150 springs on the front of my 95 bronco and 1.5-2 inch rear helpers and i'm wanting to fix my camber/caster now any suggestions? f-150 springs amounted to 2 inches of lift for the front end. now front tires are riding on the outside edges and i just installed new tires and cant drive my bronco
wileec
Erie CO
You will need a different/new/better camber bushing with more flexibility. You should be able to get it to an alignment shop 20 or so miles will not hurt
yo Bill,
This is for 96, but same;
can use info to ensure shop does work according to Fords specs;
Wheel Alignment, Front
Caster and Camber, Bronco and F-150, F-250 4x4 Vehicles
Optimum Caster, Camber, And Total Toe Settings  verify Camber & Cater Split Optimum Ranges;
94 Bronco has slightly different ranges forl
Camber split is .0+/-.5
Caster Split is -.5+/-.5
96 Bronco
Camber split is 0° ± .4°
Caster Split is -.5° ± .4°
all others are same for 94 & 96
Alignment Settings TSB 93-23-24 for 94 Bronco, F Series, Aerostar, Explorer & Ranger
Source: by Ford via Chilton http://content.chiltonsonline.com/TSB/displayTSBHandler.ashx?assetID=36533&key=6kAUBD5BruOJf%2f3tgozUqjXM3RdbjcQqW4sVWiE%2fp2IojfpfKqM07dr61%2bQAWHtTZr4ceHaQGlj8NylACcNZ4qedMqy4JdYyAXN5akgfkpHUz4aCpJyaaA%3d%3d
Partial 1996 Bronco/F-SeriesWorkshop Manual
Coastersfwb
