You'll have to buy the poly bushings separate from the hardware. The "hardware" includes the long bolt, lower washer with a nut welded to it, and both the upper and lower metal sleeves that go inside the bushings. JBg is the only place I've found that sells the hardware for the body mounts, and of course it's $400+ for a new set. It's OK to re-use your original harware, as long as the bolt threads aren't damaged or you end up having to cut apart the two sleeves to separate them. I was able to re-use all of mine except one of the front core support mounts that was rusted solid.
One other point: after you remove the old body bushings, check the condition of the brackets that mount on the frame under the cab portion. IF these are rusted out or the hole is damaged, you'll need to repair these before installing new bushings. Easiest way I've found is to weld some metal washers to the bracket. The washers have a center hole just lage enough for the center of the upper bushing to fit through without moving around. JSM84
(I'll look for a write-up on replacing the body mounts, and post a link)
Read post #10. Steve83 also has a few disgrams that may help explain how the mounts are installed:
http://fullsizebronco.com/forum/showthread.php?t=40257
I also just remembered this one from 2Bigbroncos.org:
http://2bigbroncos.org/technical/Body_Lift/index.html
You can ignore the 1" body lift spacer part)
Most shops charge about $600 to install a body lift, and I would figure about the same to replace the body mount bushings. Most likely a 2-3 day job if it takes 1-2 hours per body mount due to rust.
Hey, Ran...not feeling well. I will read this tomorrow first thing and get back to you. Thanks-
