in the market for a 71-75
huntrock
Hi all,
I am 20 years old, and really don't know a lot about broncos but since my last car got totaled, I am back in the market, and I LOVE broncos.
I have been researching online about things, and am really curious if anyone can give me some things to look for while looking, things to avoid, any advice in general is greatly appreciated. Thank you all for your time!
Hunter
S_bolt19
Colorado
Welcome to the board and welcome to the obsession Hunter. Is there a reason that you want specifically a 71-75? What are you looking to do with the rig, daily driver, crawler, mudder, show? Where are ya located too because that will effect the price of the rig. I have a 70 that I would like to get rid of, but it needs work...it is something you can definatly call a builder project, but it does run, and runs strong.
As to what to look for, look for any rust (floor pans, inner fender aprons in the engine box, under the rockers, along the body seams, tailgate, etc.) and any modifications. Make note of what they have done to the rig and if you have someone to help you look at it, take them along. If you don't, take a camera and take some pix and load them up here and we can help you out. If you are looking for something that is completely rust free that is roughly running, just needs some TLC to get going, you can expect to pay a premium (8-10k range) if it is a moderate project builder that is in decent condition, moderate rust look in the mid range (4-7k) and a complete project that needs panels replaced, engine work maybe tranny work look for those in the low end range (500-3k).
It all depends on what you want to spend and what you are capable of doing. These old rigs are easy to work on and that makes them great for first time gearheads (if that is what you are). Otherwise, you can go from mild to wild on the modification scale. About the only "original" parts on my 72 daily driver are the transfer case, body, front axle & engine block. The rest has either been replaced or upgraded at some point in time. :) /emoticons/[email protected] 2x" width="20" height="20" />
Hope that helps you out some, if you are interested about my 70, shoot me a pm and I can give you some info.
H
huntrock
I would say a daily driver, and i would actually have to say '66-'77. I don't like the '78+ as much as i like the older ones. as of right now i have 4600$, but I am saving. I would like to do a lot of the fixing up myself, it's the whole process that fascinates me. Honestly if i can get something good for a good price then I would defiantly go anywhere.
I am also in the process of moving out to Colorado (from Ohio) so I think I would put a lift kit on it as well. Thank you for the response, look forward to hearing others.
fbnwest
Virginia
Colorado eh? Hhhmm now why does that sound familiar....... :) /emoticons/[email protected] 2x" width="20" height="20" />
Welcome to the Zone, I am/were/will forever be a novice gearhead and everything I ever wanted to know about Broncos I have learned here. The part about the camera S-Bolt mentioned is excellent advice, I have had people spot numerous things wrong with my rig via pics I posted that I would have never have noticed till they went belly up. I bought my rig in Denver and saw quite a few more so I have a feeling it won't be too hard to find one out there. Good luck in your search and use the board for any questions that might come up. At least then I won't be the only one asking why I have left over bolts.
TX '73
Texas
One more thing to consider... I'm not sure what you're experience is with older vehicles but these early broncos don't drive like new cars or pickups. Rigs that have been heavily updated with disc or power brakes usually stop alot better than rigs with original drum brake setups like mine for example. They steer sloppier when compared to new vehicles too. For example my 2004 F250 steers as tight as an Indy car compared to my Bronco, but my 73 bronco steers pretty darn straight and tight for a 35 yr old rig. I definitely don't want to discourage anyone from buying an EB but don't be disappointed if it's different than what you're used to driving. Once I got used to mine I was confortable driving it anywhere, heavy traffic or off road.
But then again for all I know you could be very experienced with older type vehicles. In case you're not it may be helpful to have a friend along w/ at least some experience whenever you start test driving some broncos. Just a heads up....Good Luck!!!
Val
