Ignition Switch Problems...
BroncoNutt
What would cause the Iginition not to work? I can turn the key, and The truck wont even start?
But IF I Jump the Starter... then it starts right up?
Any body else had this problem?
Have someone help you , Take the little wire off the front fo the starter solenoid , Now have a meter ready and have your helper hold the key in the crank position , Check to see if you have 12 volts there if not then go down to the tranny and make sure the neutral safety switch is working properly it will be the red wire with the white stripe when in neutral there will be a connection between the two of them the other 2 wires in there black with a purple are for the backup lights . When you turn key to crank 12 volts goes through the switch to the neutral safety switch , If in neutral or park the 12 volts is allowed to go to the starter solenoid . :D /emoticons/[email protected] 2x" width="20" height="20" />
BroncoNutt
Thanks! I will look at that...
Do I tighten the wire? or what? The tranny was rebuild last year?
But, If thats all fine then what?
noahsdad
So Cal
If you had the tranny rebuilt then I feel comfortable in assuming that it is an automatic, if that is the case then I believe it is the starter solenoid. I have the same problem sometimes, I turn the key and here a whine, then i turn it again and it starts. It is very easy to replace just be carful when you pull the wire that is connected to the battery to make sure it does not ground out. On second thought disconnect the negative batt cable before you replace that thing, just to be on the safe side
Good possibility that its the starter solenoid, common prob. It is much easier to diagnose a problem if you add all the info on your truck, ie: year, engine size, tranny. All would be a big help. Write it out in your signature, pays off quickly
BroncoNutt
Ok I will add that in the sig.. Along with a pic! lol
It starts with the solenoid jumped... So would that mean the solenoid is bad? I Can just pick one up at an auto parts store easey. :mellow:
Sorry about not knowing a whole lot about this stuff... Im new to american Trucks!
Ive worked on Volkswagens my whole life! (im 18)
pastorbud
When my son's Bronco had this problem, it was the neutral safety switch. You can find instructions for testing and replacing it at AutoZone.com
Pull the starter, use jumper cables, put the positive on the stud and tuoch the neg on the ear in which one of the starter bolts pass through. Hold on tight, if it works no problem then re-install and try something else. If it doesnt work then just replace the starter, saves so much in headaches that way. Not much worse than changing a starter while buried in a mudhole.
BroncoNutt
Wouldnt the starter solinoid be fine if I Jumped it ( Jumped the solinoid) and it started?
Im confused!
Thanks for the link to autozone.com
I put that in my "Bronco favs" for future refference!
BroncoNutt
Ok I think that if I jumped the solinoid that means that the solinoid is open and it needs to be replaced? Correct?
OR is that wrong?
pastorbud
OR is that wrong?
If you put 12 volts on the small post with the red and white wire and your starter consistently turns over, your solenoid and starter are OK.
Get under the truck and locate the neutral safety switch (usuallyon the side of the transmission; see
http://www.autozone.com/servlet/UiBroker/?...l+Safety+Switch
Follow the wire up and you'll find a connector. Depending on which one you have it will have 2, 4, or 6 wires.
Click on figure 27 (correction: figure 26) at
http://www.autozone.com/servlet/UiBroker?F...23d800a3a41.jsp
for wiring diagram. If the switch is working, it will close in the neutral and park positions, allowing 12 volts to go to the solenoid when you turn the key to start.
You can either unplug the switch and check for continuity in neutral and park, or jump across the correspoding points on the connector, and see if the engine turns over.
BroncoNutt
Ok I will do that!
Im prob not gonna get to look at it until next weekend because I going on vacation.
So I will do that, and Check it out.
You said you had this problem on your sons... so I bet thats gotta be it!
I will post up when I can!
pastorbud
Ok I will do that!
Please note my previous post had the wrong figure no. Click on no. 26, not no. 27, for the wiring diagram.
BroncoNutt
Im pretty shure its the Neutral Safety switch... Did some testing.
Has anybody installed one? A walk thru would be helpful. Or even a link on How to's
Im gonna get a Haynes Manual Tomorrow so.. Thats gonna be helpful.
Tom
pastorbud
Tom
Yeah, I did one. Spray the whole thing with PB blaster first. Mine was a C6 tranny. Yours may be AOD (which I've never worked on) or C6. If your transmission gear indicator on the steering column has just a plain "D", it's a C6. If it's got a "D" with and "O" around it, it's and AOD (Automatic Overdrive). If it's got a little button switch on the end of the shifter to turn the overdrive on and off, its and EOD (Electronic Overdrive). Since you have the Eddie Bauer package and the bigger engine, you prob'ly have the fancier transmission, too.
The Neutral Park safety switch on mine had just two bolts holding it in. The harder part (if you have the C6 tranny) was getting the linkage loose. You need to loosen the nut on the post going into the transmission. You'll have to gently pry and wiggle to get everything off the shaft (I broke my old switch getting it off. Plastic collar had a lot of grit, and it wouldn't slide off the shaft without pressure. But, hey, that was the part I was replacing, so no biggie).
And notice the orientation for the switch. There will be a flat spot or a keyway to make sure the compontents in the switch turn as the linkage rotates the shaft going through the switch.
The Haynes manual should have pictures, hopefully with your model transmission.
ALMOST FORGOT-- the parts stores seem to have a hard time matching parts on Broncos this old. Bring your old switch in when you buy the new one, and inspect the new switch and especially the connectors before leaving the store. Make sure it matches the old one. A lot of them look a like, but may not be compatible.
Happy New Year!
BroncoNutt
Thanks... Im gonna pick it up on Tuesday or Wed... Along with some other stuff.
MississippiSlim
Or just don't use the stock switch go straight to the starter from and spring loaded push button aftermarket switch..then mount it somewhere weird and nobody but you will be able to start the truck. I had a vw with the button under the back seat...people though I was reaching in the back for something and then the car would crank...sorry not helpful but hey I like weird stuff... :) /emoticons/[email protected] 2x" width="20" height="20" /> Now if anybody can figue out why I can never start my 1962 MF135 tractor?????
Coastersfwb
