Bukd
How would I go about Finding what My truck was equipped with from the factory? Engine, Tranny, Options ETC. Would I use the VIN# or Door plate?
Thanks, Josh
Thanks, Josh
I think it wa s under the carpet on the passenger side :-& #036; but i forget what manual i saw that in.....driver door jam should have a sticker with all the options on it. I heard that was a packet underneath the driver seat too. underneath the carper possibly? I don't know how true this is. But check the jam.
1-800-392-3673 found that number in an old aticle (2006) . says call with the vin and they can send you a build sheet for free. Don't know if its still good, but worth a shot.How would I go about Finding what My truck was equipped with from the factory? Engine, Tranny, Options ETC. Would I use the VIN# or Door plate?
Thanks, Josh
I did this a couple of months ago and it worked. It's actually pretty neat to see the build sheet.Thanks I will try that out.
i didnt see anywhere on lmc where do decifer the vin. am i blind or did they change it?VIN TAG IN THE DOOR JAM IS YOUR BEST BET,LMC TRUCK SHOWS YOU HOW TO DECIFER THE VIN...WWW.LMCTRUCK.COM...UNLESS THINGS HAVE BEEN CHANGED THAT SHOULD HELP.... B)
sweet thanks!yo!11th digit - assembly plant
L = Wayne, Michigan (Michigan Truck)
Yup, Miesk5 sourced that one for us. I called a couple months back & it took them 5 or 6 weeks but I ultimately got a letter from the Ford research division with a breakdown of the VIN and a list of everything the truck had been equiped with from the factory. It was basically all the info that would have been on the window sticker.1-800-392-3673 found that number in an old aticle (2006) . says call with the vin and they can send you a build sheet for free. Don't know if its still good, but worth a shot.
