How would I find out what My truck Came with.
Bukd
San Luis Obispo, Ca
How would I go about Finding what My truck was equipped with from the factory? Engine, Tranny, Options ETC. Would I use the VIN# or Door plate?
Thanks, Josh
bryan thomas
Maryland
driver door jam should have a sticker with all the options on it. I heard that was a packet underneath the driver seat too. underneath the carper possibly? I don't know how true this is. But check the jam.
Jakes85bronco
Vancouver WA
I think it wa s under the carpet on the passenger side :-& #036; but i forget what manual i saw that in.....
Im with you though B usually the driver's door jam.....
Jersey
Thanks, Josh
1-800-392-3673 found that number in an old aticle (2006) . says call with the vin and they can send you a build sheet for free. Don't know if its still good, but worth a shot.
crazyhorse85
clarksville,tenn
VIN TAG IN THE DOOR JAM IS YOUR BEST BET,LMC TRUCK SHOWS YOU HOW TO DECIFER THE VIN...WWW.LMCTRUCK.COM...UNLESS THINGS HAVE BEEN CHANGED THAT SHOULD HELP.... B)
love_my_bronco
Spokane
thanks for the website it helped alot!
turns out
my bronco was made in good ol USA
its a bronco (really....couldnt tell)
6000 to 7000 gvw class (now that one i really didnt know)
4 wheel drive bronco
still dont know where its made. mine says L i think but its not posted ill double check tomorrow.
Thanks alot!!
Yup, Miesk5 sourced that one for us. I called a couple months back & it took them 5 or 6 weeks but I ultimately got a letter from the Ford research division with a breakdown of the VIN and a list of everything the truck had been equiped with from the factory. It was basically all the info that would have been on the window sticker.
Also, just as a bit of trivia the 9th digit is just a ck digit to confirm that the VIN is legimate. Each of the other digits has an assigned value (A=1, B=2, C=3, etc) and it's *position* in the VIN has a weighted value (1st position=8, 2nd=7, 3rd=6, etc). You have to take each digits assigned value & multiply it by it's weight value. Do that for ALL the numbers in the vin, add them together & divide by 11. You'll get a number with a remainder, the *remainder* will be the same as the 9th position check digit if the VIN is valid.
love_my_bronco
Spokane
on my door jam it says " Axle= H9" i cant find anywhere where it says what that is. any help?
