EddieBauer351
I have a 96 for bronco 351 5.8 ltr. It's very quiet! I already took the muffler off and want to put straight pipes on, please help.
That's what I want to do to, but I want straight pipes. No cat, no muffler, and blow them out the side before the rear tires. All the other stuff sounds like too much of a hassle, I guess that's a bad way to look at it though. Oh but the bad thing about the pipes going out before the rear tires is it will turn your rims green from the exhaust, mine are black so I don't have to worry about it, just a heads up.I have the dual pipe itch too, but with some questions. Erik, you mentioned running 3" pipes...pipes as in 2 pipes....My question is isn't that too big for most engines? And I thought the crossover was to balance flow and cut down resonance, not to give some back preasure.
Am I totally wrong on this? My plan is for 2 1/4 pipes to a universal cat and then a glass pack and dump our just before the rear tires. Same on each side run outside the frame. I want to be sure my plan is correct.
