greatbigphil
Hey guys,
I'm having trouble with my driver's side pow window on my 89 Eddie Bauer. The window won't go up. I was drivign around yesterday and it was workign fine, then I rolled it down one time, about half way, and that's where it decided to stay. nothing happens when I push the switch, Funnily enough, the passenger window is workign fine, as is the power locks.
Here's what I've checed so far:
- I've taken out the switch and made sure the wires are all connected, and checkd out as much as I can by just removign the interior door panel.
- The track on the bottom of the window is well lubed and the arm is not stuck
- The window isn't stuck in the track in the door, I can move it up and down a bit
- Since both side windows work off the same fuse, and the passenger one is workign fine, I'm not worried about the fuse, but I checked it anyway and it's fine
- When I push the passendger switch I see the volt meter in the dash move a bit, when I do the driver's side, there's no change in the volt meter
Any of you guys seen this before?
