get rid of 4wd????? help!!!!
mwh
I got word that the transfer case was messed up. wont go into 2wd. ball park about a grand to fix. guy at work told me to drop drive shaft to front axel and call it a day.honestly i want use 4wd.will this work????? or would be easy for me to fix????
madmaysey
won't used 4wd?
the tranfer case would still be engaged but wouldnt be applying any energy to the front axle not sure if it would fix the problem would releave the stress of the front wheels, but so would disengaging the hubs?
JLasvegas
you would need to remove the transfercase and run a longer driveshaft from the trans to the rear end like a 2wd truck
madmaysey
if he isn't worried about wear on his transfer case(doesnt care about 4wd) will pulling the front drive shaft cause other problems?
JLasvegas
Im assuming you would need to run in 4hi if you cant get it into 2, it probably wouldnt last to long at higher speeds over time
why not buy a used transfercase, ive seen them for cheap on craigslist
dsgb9840
atlanta ga
i had the same problem on my 94 EB..is it a push button 4x4 or a floor shifter. i have the push button and after a week long camping/off road trip and when i went to take it out of 4 wheel drive id did nothing. well long story short the motor that would engage and disengage 4x4 burnt out..its a cheaper fix and u should look in to that.
p.s well the transfer case was not made to go 50k miles at 50 mph..so id assume the transfer case will fail sooner than later. also you going to lose HP and TQ and MPG with the extra load of the transfer case mixed into the drive train. id say u fix it, it will cause more problems than it fixes.
Outkast
Hayward, California
i had a simular problem but all i did was put it in reverse and back it up a couple feet and it came out of 4x4 and i to have the push button 4x4
M
mwh
its manual if anyone runs into another transfer case let me know.
swampthing
New Jersey
forks inside the case are most likely bent or binding..if you want to convert to 2wd you can just put a 2wd trans in it with a new driveshaft...or just swap another case into your bronco and just dont use 4wd
