wtfdissux
not so good with carbed motors anymore but is it possible to check fuel presure at the line from pump to carb inlet andalso wouldn't the jets and metering valve restrict the flow but like I said its been a long time since I played with a carb but I do know that Edelbrock carbs are garanteed to be bolt on and go no adjusting required or recomended and for the pump pull the mechanical pump ditch it and go electric only dont run with the togle switch idea if you leave it on you can you can ruin it or worse wire it to a the solenoid so it gets power only with the key on
and lastly you say that a friend will trade you a bronco for a F-150 is that a question do it then you will have a bronco to drive while you fix the other one and besides what better back up vehicle than another bronco
